DVX400,400ex,z400
Old 10-13-2004 | 10:34 PM
rockos's Avatar
Default DVX400,400ex,z400
yea if u read the dirt wheels 0ctober 2003 addition it talks about the 04 dvx and tells u that if u had a z and wanted to turn it into a dvx all ud havta do it buy the dvx gas tank and new fenders light and seat and put em on and it be the dvx thr4e the same quad diffrent plastics so all the z shyt fits i bought z 400 nerfs and they went on easy
Old 10-14-2004 | 11:00 AM
LTZ400guy's Avatar
Bluebear!!
Ok, here is the skinny! I read that magazine and they say that the difference between the Z400/KFX400 and the DVX are the Body Plastics. Dirt Wheels Sept. 2004 issue stated that you have to make sure that the parts that you buy from aftermarket places have been tested to fit the DVX's! They were installing foot pegs and they holes did not line up quite right. Same with the aftermarket Pro Circuit 496 Pipe! That is something to consider! Granted it may miss by only a mm or 2 but non-the-less it might be more of a nuisance than a straight bolt on!
Just something to consider! Personannly I like the looks of the DVX and I like that fact that you can remove certain plastics!
Up to you!
Old 10-14-2004 | 07:47 PM
Bluebear's Avatar
ya thats true
Old 10-16-2004 | 11:09 AM
DVXer's Avatar
My Pro Circuit exhaust fit great, i got the T4 full system for a Z400 and there were no problems. The only problems you should have with parts fitting is if they connect with the body in any way. In that issue of Dirtwheels the problem with the IMS heel guards was poor craftsmanship on IMSs part, and the tab where they are supposed to connect with the body didn't quite reach the plastic because the DVXs fenders are shorter than a z/kfxs. I ordered some Alba nerfs for a Z that also connect to the fenders and i ordered them knowing they wouldn't reach, it's just something you have to put up with for being different. Great bike though.
XxS0ccerstarxX
09-24-2015 11:53 PM
XxS0ccerstarxX
09-24-2015 05:38 PM
XxS0ccerstarxX
09-24-2015 02:02 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
XxS0ccerstarxX
09-22-2015 08:07 AM
Quick Reply: DVX400,400ex,z400
