dvx400 fuel
Old Oct 13, 2004 | 11:29 PM
mikesslowyamaha's Avatar
Default fuel
Hello everyone I have a DVX400 and everynow and then when I ride it sounds like the engine is pinging I'm wondering if it woudent hurt to run like 93 octane fuel instead of 86 if you guy could give me some info it would help alot. oh ya the bike is stock and i just had it serviced for the first time they said everything loked great the valves were also adjusted.
Old Oct 13, 2004 | 11:33 PM
maddog56's Avatar
Default dvx400 fuel
Premium is a waste on a stock kawisukicat. If your bike is actually pinging on regular and you arent running in extreme heat then you have a problem with the bike, not your gasoline.
Old Feb 5, 2006 | 02:03 AM
FOURTEEN's Avatar
Default dvx400 fuel
Originally posted by: mikesslowyamaha
I'm wondering if it woudent hurt to run like 93 octane fuel instead of 86?
I'm amazed that anyone would use anything but Premium in an engine with a 11.3:1 compression ratio!! Over 10:1 usually requires Premium, even late model auto engines with sophisticated computer controls and knock sensors!
The Suzuki Z400 Shop Manual specifies: "91 octane or higher rated by the Research Method"!
Premium fuel is not 'wasted'! If operating conditions periodically require it, it is there. The slight extra cost is not even a consideration when weighed against the possible severe engine damage that could result from not using it! Since your engine is pinging, it obviously needs Premium.
PS: Always add StaBil to your gas to prevent fuel deterioration. Cheap insurance!
Old Feb 5, 2006 | 02:07 AM
v2rider's Avatar
Default dvx400 fuel
I run 92 octane every other tank of gas in my 650V2
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
