A/C 4 Polaris 0
We went riding last night. (2) AC 650v2 (1) AC 400 (2) Sportsman 500HO and a Sportman 400 (2 stroke). One 500HO was pulled out twice, Each other Sportsman was pulled one time a piece. Cats never were winched. See , theres a rivalry here, because of our sled brands too. Best part is, the Polaris boys were busting us HARD about buying "Pussies in MANS World" . Revenge is SO sweet. Me, never to let something slide, had to be a jerk! Rule #1 is if you get stuck, the other brand winches you out. After yanking the biggest offender out, I went right into where he was stuck. I stopped, put it in neutral, rev it up, said Look at me, I'm a Polaris! I started spinning, as I was coming out, and thought I was going to get stuck. CRUD ! Looked down at the speedo , (while everyone was laughing) and saw that I was in 2wd. A flick of the switch and mud was flying and the kitty pulled herself out in a heartbeat. Didn't even have to use diff lock. The Polar boys were sitting there in disgust. You should have heard them !! Now they were using stock tires, and I have 28" Mudzillas, but still, the other 650 has worn Rawhides and he never got stuck ! Anyways, I just had to gloat a bit! If you could see the abuse we took from those guys, you would too. Ahhh, revenge!!
hey shock i dunno why there is always such a rivalry between polaris and arctic cat i live 15 miles from the polaris factory and about 40 from the arctic cat factory and around here trust me there is a very big rivalry and i always hated everything bout roseau minnesota even used to work at polaris so i guess you can say i have been bleeding green for many years and well i found out that alot of it has to do with the tires number 1 rule of thumb and i was always sick and tired of polarises always doing better then me in the mud due to their on demand 4x4 system which is a step above what i call the one wheel wonder 4x4 but now that i got the 650 with a locking front diff i feel your pleasure right now cause i recently went on a mud run with 10 polaris atv's i think it was 10 or 11 anyways they all kept yelling at me cause even the ones with 28 inch mudzilla's couldn't follow me for i had the horsepower and when i would get stuck i would put the diff in lock and i was very pleasantly impressed specially when my lil 27 inch itp's were no comparisson for the ones a couple of them guys had
