o4 500 auto, has 120 miles, cuts out
Old 10-26-2004, 10:48 PM
pvwheeler's Avatar
Default o4 500 auto, has 120 miles, cuts out
Originally posted by: DitchPickle650
More than likely the problem you fellas are dealing with is a spark problem, not so much a fuel problem. The stator in the 400's and 500's goes bad once in a while, and it usually happens when riding slow, or idling , or getting warm. What happens is a wire looses connection, and looses contact when it gets warm. It causes the engine to spit sputter, and die. Minutes or hours later it will start up and run fine, but once it gets warm it does the same thing again. Hope this helps!
The stator in my wifes 04 400 act auto went bad at about 150 miles.It would just sputter and die after it got warmed up.Of course we were away from home on a 4 wheeling trip at the time [img]i/expressions/face-icon-small-disgusted.gif[/img] It would fire up again after a few minutes and run for a short time,then do it again...
I found if I pulled on the bundle of wires going into the stator I could make it quit when cold too...Dealer didnt give me any probs replacing it though.
Old 10-26-2004, 10:55 PM
farmkid's Avatar
thanks for info i will defntily check that out.
NRA+1
1) Engine problems..
10
09-20-2015 08:47 PM
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
Elkaholic
09-06-2015 02:44 PM
WilliamBos
09-06-2015 10:53 AM
Quick Reply: o4 500 auto, has 120 miles, cuts out
