swap out analog speedo for digital speedo?
If you can find an analog system that is run off a front wheel, probably. Most of the digital are run off a sensor on the tranny. This kit might work if the wheel assemblies are the same on the '05 250 and your machine. You need to go into here and compare part numbers on the front wheels.
http://www.alpha-sports.com/arctic_cat_atv_parts.htm
speedbuff
13
Nov 11, 2020 10:16 AM
