Rear mounted winch ?
Old Mar 25, 2005 | 03:36 PM
luvthemud's Avatar
Default Rear mounted winch ?
i have removed the storage compartment on my 03 500i and am looking into putting a winch back there in its place. anyone ever do this or has anyone ever seen this.
Old Mar 25, 2005 | 11:00 PM
Bear4570's Avatar
I have a buddy with a Grizzly that has fore and aft winches. I think mostly he is to lazy to figure out how to turn the bike around. when he need to use the winch. But it can be done.
Old Mar 26, 2005 | 12:07 AM
WhoDatInDaMud's Avatar
I've been looking at a rear winch setup for some time. I think I'm going to mount it up higher as my expereince has been that when I'm winch stuck - the winch is deep in it. I was even thinking of mounting it upside down under the rear rack. I have a rear winch on my Polaris pictured here under that rear basket.
I was thinking a L shaped 2 inch deal that slips into the reciever might also be a option. I can put a trailer ball on the bottom side of that L so Im not giving anything up. THat would allow the winch to be mounted a little higher than where that box is.
0|
L ---
Old Mar 26, 2005 | 12:56 AM
Bear4570's Avatar
0| | L --- ---
Now I like the reciever mount setup. Not only is it high but you can remove it if you are riding an area where it wouldn't be needed. Or even mount a reciever on the front and have 1 winch for either end and just use a welding cable plug set up to plug the power in on either end.
Bratman2
Aug 6, 2022 01:42 AM
MNatv89
Aug 12, 2015 06:00 PM
MNatv89
Aug 10, 2015 02:20 PM
Gtsordo
Jul 22, 2015 01:27 PM
cornermike
Jul 8, 2015 11:44 PM
