snorkel requirements
Old Apr 3, 2005 | 10:41 PM
themudchild's Avatar
Default snorkel requirements
i put a snorkel and blocked off the belt on my 2005 650 v2 so i dont get water in and woundered what else i need to do so i dont flood it?
Old Apr 10, 2005 | 07:26 PM
deano64's Avatar
how did you block off your belt. i am having problems in shallow water "maybe over the tires" so i need help where else could it be coming from?
Old Apr 11, 2005 | 02:35 PM
i put a piece of rubber over the vent that gose up towards the air boxs and claped it in but check the clap down in the front of your enginr that gose to the breather up front in. In some of the there websites the recommend duct tape but that did not work, the only problem is that that water sites in there now so i have to drain it after i am in water over the front fender
Old Apr 11, 2005 | 07:32 PM
MuddyPup's Avatar
Pics? I'm wanting to do mine
Old Apr 11, 2005 | 09:27 PM
deano64's Avatar
DO YOU HAVE ANY PICS . I AM HAVING ALOT OF TROUBLE GETTING WATER ON THE BELT. 05 650 LE STOCK
Old Apr 11, 2005 | 10:02 PM
limrok's Avatar
..hey guys....u r probly getting water in your belt case exhaust.....i havea problem with that at times if i have to stop in water up to the bottom of the seat.......and u shouldnt block off the belt case intake ..u could damade thongs with too much heat in the case....but u can run a pipe up to the front u have to do some modes to get it there though ...i am not sure how to do it for sure...
Old Apr 12, 2005 | 10:38 AM
not yet but i will go take some and they will be on later today
Customer Service #1
May 15, 2020 08:46 AM
BYC
Sep 25, 2015 02:10 PM
cboler9
Sep 24, 2015 08:35 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Steeldon
Sep 9, 2015 09:38 AM
