charging question
Old Apr 18, 2005 | 04:07 PM
rooch's Avatar
Default charging question
Hello, man it has been a long time since I have been on here, anyways, I have a 97 bearcat 454 and I would like to know how many amps, watts, volts whatever my quad should be putting out?
Old Apr 18, 2005 | 04:38 PM
rooch's Avatar
OK forget about my charging question I have come to the conclusion it doesn't matter how much it is supposed to be charging because it isn't charging at all!!!!!!! So now my question is how do I fix that problem and the more detail the better because I am by no means a mechanic lol.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 18, 2005 | 05:04 PM
Bear4570's Avatar
It is one of 4 things; Stator (charge coils if you prefer), Rectifier, Regulator (may be in the same box as the rectifier) or wires. If you dont' see about 14+ volts at the battery at about 2000 rpms then you have a problem. Never check it at idle. You will need a volt/ohm meter and if you don't have a manual (a must if you are gonna work on it), you can PM me you e-mail address and I can send copies of the pages from the manual.
Old Jul 29, 2005 | 05:29 PM
Baddchad's Avatar
Hey! How did you make out with your charging problem?
Just asking cause I've got the same problem with my '99 300 4x4.
Can you point me in the wright direction?
Old Jul 29, 2005 | 05:36 PM
mudslinginfool's Avatar
Does it in the Mud!
i had a 99 300 and the problem was the voltage regulator. it cost me $80.00 (in missouri)and the dealer had one in stock.
Old Jul 29, 2005 | 05:53 PM
Baddchad's Avatar
Thanks for the info!
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
cornermike
Sep 10, 2015 08:30 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
bmark0610
Sep 7, 2015 09:42 PM
Elkaholic
Sep 6, 2015 02:44 PM
