shaving heads on dvx 400
Old Aug 4, 2005 | 12:45 AM
dvxr's Avatar
Default shaving heads on dvx 400
dose any buddy know the valve clearence to the piston for a dvx 400 or know how much u can shave of the top of the jug? am just looking to shave the jug and port and polish the head... thanks brandon[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 4, 2005 | 10:56 AM
Speedwerx's Avatar
Brandon, are you looking to do this yourself? Alot of shops/companies will not give out info like this becuase thye do the homework and development on it to see what works and that is how they stay in business you can through alot of parts if somthing is not done right an d it can be very expensive as well. What do you have done to your dvx already?
Old Aug 4, 2005 | 06:18 PM
Nicname's Avatar
Most people don't shave the heads on four-strokes. A better alternative to bump the compression of your Z-400 based motor is installing a DRZ-400 base gasket. This will move the head and cylinder down a small amount essentially raising the compression ratio.
Old Aug 4, 2005 | 11:30 PM
dvxr's Avatar
thanks for the info i will try that first and see what happens.. thank u brandon
Old Aug 4, 2005 | 11:31 PM
dvxr's Avatar
am in the middle of putting cams and a big bore in it right now.. i already have it pipe and jeted.. thanks for the info .. brandon..
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
