I want to buy this Cat (Pics)
First make sure the choke (actually an enrichener) is tuning clear off when the choke lever is up. Second could be a tank vent plugged. Either loosen the cap and run it or pull the vent hose, blow thru it to see if clear (I have seen bug crawl into the hose and plug them) and then push a wire down the vent nipple on the tank to make sure it is clear. Look here for info on the shifter:
http://forums.atvconnection.com/mess...yword1=shifter
I have the parts numbers on the invoice somewhere if you want them. Oh yeah finally had a problem with the shifter mod. collected enough dirt in the heed/toe pivot that I had to pull the nut off and clean, lube and reassemble it, such a high maintenance item.
Thanks Bear,
I looked up those parts online and I think I've got a handle on what I need. It seems like you have to get a new pedal because the bellcrank is at a different angle. I won't be making the change just yet. I want to ride it around a bit first.
Harry in PA
Harry in PA
Quadzilla Heritage
09-25-2015 01:39 PM
TLC
Utility ATVs
09-16-2015 01:41 PM
