Need some honest opinions
#21
I had an 04 650 and the first thing I did to it was replace the stock tires with Bearclaws. It did improve the handling but did nothing to improve the heavy steering. I've since bought a Polaris 800 and the handling/steering difference between the two is like night and day. Like a previous post stated, it's like moving from manual steering to power steering.
#22
What is truly amazing is the complete opposite experience and opinion some of us have. I've posted many times how I wouldn't use "my" Polaris 500 for hunting any longer as its steering requires so much effort when traversing a off-trail side hill and the AC can be ridden one handed on the same hill and same conditions.
I'm not saying anyone is wrong. I believe we can have different interpretations based on variable factors such as front wheel alignment or different tires - ie examples I have expereince with. And I'm sure there are numerous other variables that play a role that I don’t' even know about but someone else may be dealing with.
Reason is when we understand that our experience is not the only experience possible. - Arthur W Collins
#23
I have found that most heavy steering problems are caused by mis-alignment, rather than anything else. I have found that the factory setting of a 1/4' toe in is to much. I found 1/8" or 1/16" works better and tire pressure is critical, never less than 4 psi, 5 psi is better (actually 5 psi is spec. by the way).
Customer Service #1
05-15-2020 08:46 AM
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
