Future 700 EFI Owners, The Lag Needs To Be Fixed!
Old Feb 1, 2006 | 06:15 PM
RedGoblin's Avatar
Default Future 700 EFI Owners, The Lag Needs To Be Fixed!
You guys are probably geared lower than the Suzuki, but make no mistake about it, the lag is still there built into the ignition timing (hasn't really been PROVEN yet, but we're pretty sure up to this point, will let you know if that changes). That lag may just be enough to lose that drag with your buddy or not make it out of that mudhole. Get on the aftermarket performance electronic companies to make a timing module or ECM for the Suzuki/Arctic Cat 700 EFI! For more info, check out the Nyroc Forum (atv.dnsalias.com) under the KingQuad section.
Old Feb 1, 2006 | 11:23 PM
hero's Avatar
just stick with the H-1 or the v-2 and problem solved
Old Feb 2, 2006 | 09:59 AM
Hoopie's Avatar
all the mag reveiws says the h1 is faster out of the hole then the 700 flies buy it. There must be a lag for sure.
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
Kenidah
Sep 7, 2015 07:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Brandon400
Sep 5, 2015 08:44 PM
cdstang
Aug 31, 2015 07:52 AM
