Cables - How do you lube them?
Old Mar 13, 2006 | 01:48 PM
JimJa's Avatar
Default Cables - How do you lube them?
Comments have been made that the best way to keep the choke cable from sticking is to lube it. I agree it's a good idea to lube all your cables, but how do you do it?
Old Mar 13, 2006 | 07:27 PM
spike99's Avatar
In the summer, I use clear thin oil only. Like WD-40. When it needs a good lube, I remove the cable, soak it in gasoline 48 hours, then re-lube with WD-40 (before re-installing). Usually, I do an end/end re-lube every other year. Works for me....
Old Mar 13, 2006 | 08:32 PM
swampyjunior's Avatar
I thought you could not lube the newer cables on ATV's. Due to the teflon coating inside the cables?
I have a little clamp that I have used to lube the cables on my old CanAm 125 motorcycle and my old Suzuki 4 wheeler. You remove the cable, put this clamp on, and spray with a can of lube through a little nozzle until the stuff runs out the other end of the cable. It works great and is fairly cheap. I have seen then on Rocky Mountain ATV web site.
I just thought you couldn't use them on the newer cables that have a teflon lining. I was told it would cause the teflon coating to separate from the inside of the cable lining and put the cable in a bind so the cable would havet difficulty to moving.
SJ
Old Mar 13, 2006 | 10:39 PM
weez440's Avatar
instead of using wd-40 i have found out for guns and well everything that amsoil works way better doesn't seem to film up.
Old Mar 14, 2006 | 12:08 AM
btemefordboy's Avatar
i have used graphite
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
craacker
Sep 9, 2015 04:32 AM
bmark0610
Sep 7, 2015 09:42 PM
