2005 400 4x4 warn winch install info
Old May 8, 2006 | 11:37 AM
Nats's Avatar
Default 2005 400 4x4 warn winch install info
Yes another install question for the winch! I did not see any asked for my machine and since I get to keep from my early stated divorce (good job mr $200 an hour lawyer) I have an 05 400 4x4 man. I gave all my hard earned money to my ex and my lawyer and can now afford to buy winch but will need to save on the install charges. I am a 2 level handyman on a scale of 10. What are the basics for an install? the electric is what is scary for me....any suggestions or good how to websites you can offer?
Old May 8, 2006 | 01:26 PM
Bear4570's Avatar
I installed mine in November 2004 when I bought my 2005 400 4X4 manual. I got the $69 winch and the kit was complete. The hardest part was finding the accessory plug which was buried in the wiring harness behind the cylinder across the top of the tranny. Otherwise it was a straight forward install with the instructions being very clear. Even though I was a professional mechanic, I had had surgery on my left arm and hand and did most of it one handed and still only took a couple of hours.
Old May 8, 2006 | 01:55 PM
sevenmag's Avatar
I bought a venom winch off of ebay for $99 plus shipping. I had it on in about in less than 2 hours. You will have to drill under the seat to put the module. I'm a 1 on the handyman scale but it is not rocket sceince. Also you will get the mounting plate for the ac and the roller fairlesd with the venom kit. Good luck
Old May 8, 2006 | 02:28 PM
Nats's Avatar
Warn the best to go with? I looked on ebay and see several other brands for much less.....understanding you get what you pay for is there any cheaper but quality optinions to Warn?
Old May 8, 2006 | 06:27 PM
Bear4570's Avatar
The Warn kit from AC comes with the mounting plate, roller fair lead and all wires, nuts & bolts, relays, fuses, switches, mounting pieces and great instructions. Admittedly I only paid $69 when I bought it when I bought my 400 but it would have been worth it at full price. For my 2001 250 I bought a Harbor Freight $50 2000# winch, then the AC mount plate and roll fairlead and used some switches, wire and solenoids I had laying around to make everything work. I spent more time figuring out where to put everything and routing wires than I did installing the whole Warn on my 400. The cheapy winch works fine and for the 250 is a great addition, but the Warn works better and was a lot easier to install because I didn't have to think, just follow instructions. The old KISS! principle, You know "Keep It Simple Stupid!".
Old May 10, 2006 | 07:44 PM
Muddin250's Avatar
try searching Gorilla brand winches on ebay very cheap yet very reliable comes with everything you need to install it, it's a Warn knock off.
Old May 11, 2006 | 11:13 AM
Nats's Avatar
Muddin250,
do you have one?
toonces
Oct 19, 2015 02:21 AM
Bratman2
Jul 23, 2015 12:36 PM
Gtsordo
Jul 22, 2015 01:27 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
