air filter upgrade
Old Jun 1, 2006 | 06:01 PM
rango726's Avatar
Default air filter upgrade
ive been in the market for a new air filter and wanted something that breathes a little better than stock any suggestions. also ive noticed lately any time i cross water deep or not i end up with some water in the air box im not flying through water or going very deep usually not over the tires but this cant be rite i dont think there should be any water unless im pretty deep am i rite or wrong. thanks
Old Jun 1, 2006 | 06:59 PM
Muddin250's Avatar
K & N lot better airflow
Old Jun 1, 2006 | 10:59 PM
Bear4570's Avatar
A K&N with a prefilter is the only way to go if you are gonna change from stock. Make sure the is nothing stuck in the air box drain tube valve that is holding the valve open. As long as all the hose clamps are tight that is about the only way to get water in the box without either hot hodding thru the water or going so deep you get your butt wet if still sitting on the seat.
Old Jun 2, 2006 | 10:53 AM
Speedwerx's Avatar
What quad are we talking about here? Most likley a k&n will be best for you plus after you get it you will never need another filter for that quad becasue you can wash and clean the k &n's very easily. You shouldn't have to worry about rejetting either the only ac model that needs rejetting aftera k&n is the dvx 400 which I doubt that is what you have. Anyways let me know what quad I can get you a price on one if you want.
Old Jun 2, 2006 | 11:43 PM
rango726's Avatar
i own a 2006 arctic cat 400 4x4 auto fis its got approx 500 mi or so if that matters i would like a little more power out of the quad without having to rejet and all that so whatever air filter is going to give me the most gain and i definately want one of those prefilters as extra protection thanks for your time
Old Jun 5, 2006 | 10:58 AM
Speedwerx's Avatar
A filter and clutch kit would suit your needs best IMO. Filter adds a coupel of hp and cltuch kit helps aid in acceleration and backshift.
Old Jun 5, 2006 | 12:23 PM
rango726's Avatar
a clutch kit is a little more than i want to get into rite now but eventually i would like to go for oversized tires and a lift maybe after i pay the beast off but as far as just an air filter and cover what am i getting into
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
