Cat won't get past idle...HELP!!!
Old Jul 25, 2006 | 04:01 PM
RobAlford's Avatar
Default Cat won't get past idle...HELP!!!
I have 2000 500A that idles perfectly but misses even slightly above idle and dies past that. I have gone through the carb it looks good, there was a dirt dobber nest in the carb vent... thought that was going to be it, but... no better. Does anyone have any ideas? Am I missing something simple? [img]i/expressions/face-icon-small-confused.gif[/img] Thanks in advance, Rob [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 25, 2006 | 04:14 PM
Bear4570's Avatar
Does it do it in the reserve position on the fuel shut off valve? If not you have a plugged screen in the main pickup in the tank or crap in the main feed to the valve or at the valve itself. It could be a spark plug issue. When is the last time you changed the plug and if over a year or a 1000 miles, change it because it is the smart thing to do.
Old Jul 25, 2006 | 04:20 PM
RobAlford's Avatar
I haven't changed the plug, I did pull it and clean it. I'll try to get on and replace it though. It does the same thing in reserve the fuel seems to be getting to the carb fine. Thanks
Old Jul 25, 2006 | 05:42 PM
TROX90's Avatar
i had kind of the same problem wihth mine. it WOULD NOT get into any high rpm's. it would start choking and die. i changed the plug and it runs great. i also put carb cleaner in the gas.
Old Aug 1, 2006 | 01:53 PM
RobAlford's Avatar
It wasn't the plug, went through the carb again thought I found a little trash in a jet, reinstalled, same thing. Unplugged the harness from V. regulator to charging coil revs fine. Checked coil, it's okay. Pulled the fuse panel up... seems to be working fine like that. I guess there is a short somewhere in that area. Will look at it later. Thanks, Rob[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 1, 2006 | 06:06 PM
weez440's Avatar
is it possible that you don't have your main jet set correctly? are you running it to rich? and if it was electricle you would be blowing fuses so i doubt it would be that. could your fuel filter be plugged?
Old Aug 4, 2006 | 12:15 PM
Cruff's Avatar
Have you checked your air filter...
I had a 03 500 that did the same thing. I had to change my air filter and my spark plug....
Old Aug 6, 2006 | 01:18 AM
RobAlford's Avatar
Air filter is clean, plug is new. It's cutting up again, it's something electrical. If I unplug the V. Reg. it revs fine. I don't know if it is the regulator or something down stream from the reg. Well, I'll keep lookin'. Thanks, Rob
Old Aug 6, 2006 | 03:08 AM
Bear4570's Avatar
The only thing down stream of the voltage regulator is the battery.
Old Aug 19, 2008 | 08:55 PM
Masterike's Avatar
Default Cat won't get past idle...HELP!!!"></title><script src=
Well my 454 is doing the same thing it bangs out at half throttle. but I pulled the regulater loose and it still happened so if you get this figured out please post it.
