Anyone have a....
Old Jul 28, 2006 | 10:57 AM
Cruff's Avatar
Default Anyone have a....
Does anyone have a cluch puller that want to get rid of???
http://www.mfgsupply.com/m/c/PCP10.html
I one need to tighten my belt!!!!
Old Jul 31, 2006 | 03:41 PM
Cruff's Avatar
come on!! no one
Old Jul 31, 2006 | 06:04 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
I don't know anyone that uses one, it is not necessary and an expensive tool at that.
Old Apr 26, 2007 | 07:19 PM
AirJunky's Avatar
So what do you suggest, Catterman? Everything I've read says the shaft is tapered so the clutch will be hard to get off, even with a puller.
Or do you not need to pull the entire primary pulley? Ie; seems like you could pull the center bolt & the 6 or 8 outer bolts, pull the top piece & the spring, then the belt should slide off.
Right?
Old May 9, 2007 | 03:40 PM
AirJunky's Avatar
I bought the puller at my local Cat dealer for $24.95. There is no way I would have gotten the primary off without it. I tried using an impact wrench, nothing. Smacked it a few times with a 3 lb hammer, then the impact again, nothing. Removed the puller & packed the hole full of grease, then impacted it again, nothing. Smacked it a few more times with the 3 lb hammer, then impacted it again & it pulled it off.
I greased the shaft good so it's not as tough to get off the next time.
MuddFoxx10
Jan 20, 2008 01:16 PM
hondariderAR
Dec 18, 2004 12:17 AM
mertle
Nov 27, 2001 04:59 AM
