Carb Adjusting
Old Aug 3, 2006 | 02:51 AM
DikTok's Avatar
Default Carb Adjusting
I have a 2003 AC 400i, with a HMF exhaust . It has the quiet core and spark arrester installed. I have a stock 150 main jet in it, and i turned the air screw out one extra turn. The bike pulls good on low to mid range, but falls very flat in upper rpms. I tried jetting up one size 152 and it ran better, but the spark plug looked very sooty. I ride at low Elevation 700-2500' Any ideas an adjustments? Is a carb kit the way to go,or should I go back to stock? PS It has the manual transmission. Thanks for any help.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 3, 2006 | 04:29 PM
hondabuster's Avatar
Doing a plug chop, must be done right...or the plug reading doesnt mean much. Just go by the drivability symptoms, and youll get it right.
Dont bother with a jet kit...the piece of paper is very expensive...the jets are cheap.
Heres a good article on jetting yourself, and it lists the drivability symptoms to watch for.
Jetting
If its still breaking up, at WOT, then youll need to go bigger on the main.
Old Aug 3, 2006 | 10:48 PM
DikTok's Avatar
Thanks for steering me in the right direction. It did run better with the 152 in it. I will put it back in and try adjusting the air screw and see where it is at. Thanks again
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
