Anyone running '02 and up rims on a 2000 model?
Old Aug 17, 2006 | 07:13 PM
RobAlford's Avatar
Default Anyone running '02 and up rims on a 2000 model?
I found a set of aluminum rims for '02 and up for forty dollars each. Could I run them with spacers? Anyone ever tried?
Old Aug 19, 2006 | 05:24 PM
weez440's Avatar
i dunno if the bolt pattern is the same on them i guess i would look it up before purchase. i would look up tire kits in Ronnie's and see if the 02 and the 00 rim pattern is the same. i don't think you would need spacers all that would do is put added stress on the machine even though it would make the stance wider which would be nice.
Old Aug 31, 2006 | 07:20 PM
sammydogs64's Avatar
I have a set of 05 AC650 wheels and tire 26" gooyeers with 12 miles on them if you are interested. $150.00
Old Sep 6, 2006 | 11:54 PM
RobAlford's Avatar
Are your rims aluminum or steel?
Old Sep 7, 2006 | 05:40 AM
Factory steel
Old Sep 7, 2006 | 10:15 AM
Mudpuppy193's Avatar
Aluminum aftermarket ones should work but the stock steel ones wouldn't due to wheel to brake caliper clearance issues w/o a spacer. As far as offset and lug spacing, they are the same. The only thing you may find is some clearance issues with the circle on the end of the hub being a extremely tight fit to the hub hole of the rim. I know the ITP rims will fit fine.
Boss70
Nov 4, 2000 07:42 PM
balzer1972
Apr 30, 2000 08:07 PM
JKB
Feb 16, 2000 06:34 PM
JKB
Feb 16, 2000 07:54 AM
jgardn1
Nov 28, 1999 09:46 PM
