Radiator/Coolant Question
Old Sep 14, 2006 | 07:52 PM
acpower's Avatar
Default Radiator/Coolant Question
well i went ahead and spent the $30 to buy engine ice and get it shipped here. then i find out that i shouldnt run it in the winter, good thing i didnt put it in. so today i went to the hardware store and bought their best product, which was a high-performace coolant/antifreeze. i used a 70/30 ratio mixture instead of the normal 50/50 to try and achieve their -86oF freeze point and 176oF boilover point. just wondering 1st off if that was a smart move or not. didnt say anything in the manual not to use 70/30 and the bottle said not to use less than 50/50 or more than 70/30. so i flushed my system and put my new mixture in.
i drained the reservoir also and see that no coolant is in there after i filled it. should i fill that myself manually or will the system fill it. if im supposed to fill it manually should i fill it to full cold or full hot. thanks for any help.
Old Sep 14, 2006 | 11:30 PM
v2rider's Avatar
You have to manually fill the res. Also, you could run straight antifreeze, and it wont hurt anything. 70/30 is fine.
Old Sep 14, 2006 | 11:46 PM
acpower's Avatar
thanks v2. youre not as dumb as catterman says afterall. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 14, 2006 | 11:48 PM
v2rider's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 24, 2006 | 10:14 PM
Speeddrive1's Avatar
The water in the 50/50 mixture is what helps with the cooling capacity. Too much antifreez actually will make you run hotter because the antifreeze only keeps the water whitch actually does the cooling from boiling or freezing. To pay 30 dollars for antifreeze is nutz. A 50/50 mix of distilled water and regular old antifreeze is all you should use.
Old Sep 25, 2006 | 11:21 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
I still think he is [img]i/expressions/face-icon-small-happy.gif[/img]
I just put some new antifreeze in mine too. THe H1 doesn't even have an overflow resivor. [img]i/expressions/face-icon-small-shocked.gif[/img]
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
