500- no power with key on
Old Oct 20, 2006 | 11:42 AM
colling's Avatar
Default 500- no power with key on
Hoping you can help with this one! I lose power to the red wire in the ignition switch when the key is turned on. When the key is off it is at 8.5 volts. I can send a direct 12v line from the battery to the red and the machine runs perfect. should the red wire have 12v or 8.5? what would cause the red to die when I turn on the key allowing power to flow to the orange?
Thanks in advance for any ideas!
Old Oct 20, 2006 | 02:17 PM
Bear4570's Avatar
Bad, corroded or dirty connection at the fuse in the fuse box or at the solenoid terminal from the battery or the plug under front plastic below the insturment head. It should be 12 volts or whatever the battery is at.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
