Squeaking rear '06 400
Sqeaking rear '06 400
I haven't ridden my bike all that much since I bought it, but after I took a little spin on it today around my property I noticed some squeaking coming from what sounded like the right rear wheel, possibly the c/v joint. I don't think it's anything major, just haven't had time to investigate. Just wondered if any of you guys had experienced anything similar, to save me some trouble. I don't have very many miles on it and I haven't been too hard on it, so it can't be anything major like bearing failure. Anyway, any similar experiences would be appreciated. Thanks.
I have had the same problem on my 06 500, and the only remedy that I have found is temporary. I removed the rear brake pads and with a light sand paper scuffed off the raised areas on the pads. If you do this make sure that you do another brake burn in like you should when the brakes are new. IMO
Chasso
2) Chassis problems..
09-19-2015 03:06 AM
