High or Low
Old Jan 22, 2007 | 12:10 AM
weez440's Avatar
Default High or Low
don't be sorry stihl look at it as being educated for your own benefit in the future. that is what we are here for is to help each other out [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 22, 2007 | 12:27 AM
cat4life's Avatar
Default High or Low
Has anyone heard of disconnecting the engine brake actuator? I read on one of forums that someone did that and it made a difference at low speeds as well. I know on mine when I start out it feels like I have the parking brake on. I guess anything under 5 mph the engine brake does not fully disengage?????????????????
What do you think?
Old Jan 22, 2007 | 12:41 AM
gtdoctor's Avatar
Default High or Low
For slow trail riding, with no large hills, it does seem to be a little nicer ride with the engine break disconnected. I ride with mine disconnected about half the time. If you want to try it, just pull the fuse labeled "actuator", and see if you notice any difference.
Old Jan 22, 2007 | 07:19 PM
stihl's Avatar
Default High or Low
I am new at this. That is why I ask questions.
Old Jan 22, 2007 | 10:09 PM
  #15
3dogs's Avatar
Default High or Low
Good question I learned. Called dealer today they said LOW also, unless on flat smooth surface. Keep asking
Old Jan 23, 2007 | 02:47 PM
  #16
catdude's Avatar
Default High or Low
I ride my auto 500 in high alot of the time, but after reading this topic --- I'll be switching to low gear from now on --- thanks for the great info guys [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 23, 2007 | 03:01 PM
  #17
Bear4570's Avatar
Default High or Low
The 500 has a different tranny and belt system.
Old Jan 23, 2007 | 03:09 PM
  #18
catdude's Avatar
Default High or Low
so does that mean running it in high is alright ?
Old Jan 23, 2007 | 03:15 PM
  #19
Bear4570's Avatar
Default High or Low
Normally yes, but you need to use some common sense here to. If the going gets rough or steep, you damn well won't hurt anything in low range, well maybe the gas mileage a little but if you wanted real gas mileage you won't have bought an auto anyway. I run my 400 manual in low range on steep or rough trails because the gear spread is closer and I can keep the engine in the power band easier.
Old Jan 23, 2007 | 03:39 PM
  #20
catdude's Avatar
Default High or Low
thanks bear
I normally do ride my bike in low on rough terrian or tight trials where speed isn't an issue. My bike is 3 years old and I haven't had a problem yet *** knock on wood*** [img]i/expressions/face-icon-small-smile.gif[/img]
