prowler question
Old Feb 1, 2007 | 08:02 PM
Bear4570's Avatar
Default prowler question
Originally posted by: oledad
The only way I would haul one would be with cinch down tiedowns of a very large size that would not break under extreme pressure.
Your response ignores the fact that the load has to be tied down and if you don't you are stupid enough to need to die from an ATV crashing thru the cab. I use 4 each 2500 pound tie down on a 700 pound load. Even the old formula "Velocity squared X mass = energy" isn't going to make it that heavy. So the extra couple of hundred pounds of the Prowler just isn't an issue. Yeah, I watch Mythbusters just to see how wrong they are in their methods and conclusions. It's good TV, but scientific is isn't.
Guess in your haste to as usual show US All you (in your mind) are ALL KNOWING you missed the last part of my post.
And I don't think anyone needs to DIE from a mistake in judgement as you seem to do by your post. And just a FYI a 2500 Lb strap is only as good as the hook it has and its mounting point.
Gee, I'm sorry, I'm not perfect like you! Must be nice to never make a mistake or forget something. One of the biggest problem this country has is people like you who ignore natures first law. "Stupid people are suppose to die so their shallow end of the gene pool, genes are not passed on."
Old Feb 1, 2007 | 08:41 PM
gtdoctor's Avatar
Wouldn't it be nice to discuss different subjects, maybe even disagree on occasion, without the childish insults?
Just a thought.
Old Feb 1, 2007 | 08:50 PM
v2rider's Avatar
Hey gtdoctor, how do you like your V2 so far?
Old Feb 1, 2007 | 09:06 PM
gtdoctor's Avatar
Fantastic, I have zero complaints so far. Only problem I have had is engine break actuator replaced under warranty (kawi part). From my experience, I have no problem recommending the V2 to anyone. I haven't done much as far as mods yet other than clutch springs and tires, 26 mudlite xtr's. The only other thing I would like to try is a different coolant so my fan will run less in the summer. By the way, is the coolant drained at the bottom of the water pump like on the H1? Never done it before, and I'm not sure how to drain all the coolant out.
Old Feb 1, 2007 | 09:33 PM
  #15
v2rider's Avatar
The hose at the bottom of the radiator comes off, thats how i drain mine. I reccomend Engine Ice, it cut my fan time almost in half. You should drain the radiator, fill with water, run a few minutes, drain again, then add Engine Ice. You can run it as your main coolant, as it protects to -27F. I like it alot
Old Feb 1, 2007 | 09:43 PM
  #16
gtdoctor's Avatar
Thanks V2.
Old Feb 2, 2007 | 11:13 AM
  #17
oledad's Avatar
[quote]
Lucky for you that isn't how it works, If it did you wouldn't be here.... LOL
Old Feb 2, 2007 | 07:14 PM
  #18
weez440's Avatar
one of the reasons your fan runs so much is cause of the winch. as i sure you have noticed the winch covers up half the radiator. mine runs alot but has only overheated one time and well my own fault cause the radiator was packed with mud and it was about 100 degrees out and my gf and i were riding it on a looser gravel road. and may i highly recommend a dynatek cdi. i swear i think i should become a salesman for them things lol [img]i/expressions/face-icon-small-smile.gif[/img] good luck with it though
Old Feb 2, 2007 | 07:57 PM
  #19
Bear4570's Avatar
[quote]
And that attitude is exactly why you will never be in that position![img]i/expressions/face-icon-small-tongue.gif[/img] It's gotta be your way or the highway. That makes you wrong.
Old Feb 2, 2007 | 11:35 PM
  #20
weez440's Avatar
damnit bear u r the most childish contankerous old fart i have ever knowen in my life. you are always looking for a fight which pushes good people away. we come on here for the same reason to all become more knowledgeable in our sport to make the right or better decisions. i think it is time for you to grow up and stop treating every situation as an opportunity to start an arguement. i agree with you about using a truck to haul an atv safely, but i do not agree with you as to how you try to get your point across.
