High Lifter Springs
Old Apr 12, 2007 | 02:31 PM
buckaroo50's Avatar
Default High Lifter Springs
Has anyone tried the High Lifter Yellow Springs on their AC? They claim the High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set). And gain 1/2 to 1 inch of ground clearance. I'm thinking of trying some on the back as I have to now run my preload on the 4th notch so that they don't bottom out.
Old Apr 13, 2007 | 08:33 AM
CrashinIt's Avatar
i have them on my 04 650, what i have found is that they are so stiff the actual shock once compressed will not return to full " expanded" position. Maybe my shocks are worn out or something. But they do make it siffer if you are a big guy and carring heavy loads
Old Apr 13, 2007 | 10:22 AM
buckaroo50's Avatar
I don't understand what you mean about 'expanding'. If the shock compresses the spring itself should push the shock back out. The spring is always going to try and keep the shock at full length. I am confused as to what you mean....
Old Apr 13, 2007 | 01:43 PM
oledad's Avatar
Had them on a polaris, they are stiff! I see no need for them on a ac the springs are plenty stiff already.
Old Apr 13, 2007 | 05:30 PM
buckaroo50's Avatar
Thanks guys, I don't have a good dental plan and don' t want my teeth jarred out of my head. So I guess the High Lifter springs are out. Maybe some Progressive springs...
shimanok2
Jan 29, 2016 07:37 PM
fredrikrosen
Sep 28, 2015 09:58 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Steeldon
Sep 9, 2015 09:38 AM
