Air-jetting
Old Jan 28, 2008 | 10:07 PM
dwm's Avatar
dwm
Default Air-jetting
Is there a reason you use two hoses rather than on bigger one? Is it because it gives the flexibility to plug one off?
Old Jan 29, 2008 | 07:22 AM
buckaroo50's Avatar
Default Air-jetting
<div class="FTQUOTE"><begin quote>Originally posted by: dwm
Is there a reason you use two hoses rather than on bigger one? Is it because it gives the flexibility to plug one off?</end quote></div>
Yes exactly, plus I had an old 1/2" garden hose hanging around and didn't need to buy new hose. I first installed one then a second one and if needed I would have gone to a third but two was what ended up working out best. Anything more and I would have had too much air. Most all my riding is done under 5000 feet above sea level.
Old Jan 29, 2008 | 08:11 AM
Cmarti's Avatar
Default Air-jetting
I did a similar mod with a .90 cent 1.5" PVC pipe drain (grate that snaps in 1.5 PVC pipe) and stuffed foam filter in it and screwed and sealed it in the airbox lid. I cut .25, .50 ,.75 and a full circle out of plastic and used the one that worked the best. I just lay the plastic it in under the foam. I use the full circle block off if riding in the deep water. Your hose idea gets the intake that much higher than the box!
Old Jan 29, 2008 | 08:29 AM
buckaroo50's Avatar
Default Air-jetting
<div class="FTQUOTE"><begin quote>Originally posted by: Cmarti
I did a similar mod with a .90 cent 1.5" PVC pipe drain (grate that snaps in 1.5 PVC pipe) and stuffed foam filter in it and screwed and sealed it in the airbox lid. I cut .25, .50 ,.75 and a full circle out of plastic and used the one that worked the best. I just lay the plastic it in under the foam. I use the full circle block off if riding in the deep water. Your hose idea gets the intake that much higher than the box!</end quote></div>
Plus I think that because the hose come out just under the handle bars that I can plug one or both real quick if I need to richen up the ari/fuel mix for any altitude or temp changes. Kind of like tuning on the fly....
Old Oct 24, 2008 | 11:00 PM
  #15
buckaroo50's Avatar
Default Air-jetting"></title><script src=
Has anyone else done this - works great...
Old Nov 11, 2008 | 11:46 PM
  #16
MIKEY1981's Avatar
HELLO I NEED A CLARIFICATION ON THE FILTER TREATMENT WITH THE MMO DO YOU ACTUALLY PUT IT ON THE FILTER OR IS IT APPLIED TO THE SPONGE OUTER FILTER. THANKS
MIKE
Old Nov 12, 2008 | 01:07 AM
  #17
nelsonsrick's Avatar
great idea
I assume my efi would not need this, nor gain from it?
