what to grease/oil
Old Aug 6, 2007 | 10:11 AM
acpower's Avatar
Default what to grease/oil
i have an 06 AC 650 V2. All i ever do is change the regular oil and differential oil. is there anything else i should lube/oil? thanks.
Old Aug 6, 2007 | 04:03 PM
buckaroo50's Avatar
Maybe once a year re-pack your wheel bearings and replace the seals, that is what I do. I start in the late winter, early spring time and just go through the whole bike, check shock and A-arm bushings, ball joints, change differential oil, valve adjustment, wheel and steering bearings clean the oil strainer (need to remove the skid plate for that) etc etc.... If I find anything starting to wear I replace it. It usually cost me less than $50.00 to end up with basically a new bike.
Noodlez_DS650
Feb 20, 2008 05:16 PM
BloodSweatAndBeer
Dec 10, 2007 01:49 AM
laker
Jan 30, 2007 07:48 PM
Raziel
Dec 12, 2004 01:15 AM
