arctic cat 500 gas millage????
Old Aug 22, 2007 | 11:12 PM
brad_smalley's Avatar
Default arctic cat 500 gas millage????
i have a 2005 arctic cat 500 manuel and i wanted to see what kind of millage other people are gettin because i am only gettin about 6 miles a gallons 25 to 29miles on a tank of gas (4.75 gallon
Old Aug 23, 2007 | 07:46 AM
arcticman69's Avatar
i have a 06 500 auto and i get over 120 miles a tank (6.5 gallon) and thats ridding pretty hard i figured it out to be alittle over 20mpg hope this helps
Old Aug 23, 2007 | 07:53 AM
KINGQUAD450's Avatar
I think that would be way to hard to compare milage. It depends on what type of riding you are doing and how fast, ect.
Old Aug 23, 2007 | 10:07 AM
backwoodsfisherman's Avatar
with my 02 500 auto I am getting easily 65-75 miles.
thats with an 18litre tank and riding double in rough terrain
Old Aug 23, 2007 | 12:37 PM
deanz400's Avatar
I get close to 30 mpg with my Z400
Old Aug 23, 2007 | 02:26 PM
buckaroo50's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: brad_smalley
i have a 2005 arctic cat 500 manuel and i wanted to see what kind of millage other people are gettin because i am only gettin about 6 miles a gallons 25 to 29miles on a tank of gas (4.75 gallon</end quote></div>
That seems pretty low. Almost sounds like you are in low-range instead of high-range.
Some things that you can do:
Make sure you have a very clean air filter.
Check your spark plug for air/fuel mix and if a rich condition exist then you need to check your carb choke for correct operation and you can also increase the amount of air getting to the air box (air-jetting) and/or put a smaller jet in the carb.
Some other things that you can do is to repack your wheel bearings, change the differential fluid. Adjust your toe-in (between 1/16 and 1/8 inch), check your CV boots to see if any are leaking and have gone dry. Pump up your front tires to around 8 lbs and the rear to around 5 lbs.
Get rid of extra weight - Make your girlfriend/wife walk - LOL...
Old Aug 25, 2007 | 02:54 AM
JohnO's Avatar
Getting around 80-90 miles before going on reserve on my 02 500i manual. That's mostly slow and fast riding, dodging trees and pulling moderate hills.
Comes out to around 18mpg. Probably does a lot better on flatter trails.
Old Aug 25, 2007 | 04:42 PM
Chumley's Avatar
I've gotten 6mpg with my V2 before, but that was a really hard day for the machine. I was either ***** deep in the carb, or white knuckles on the brake the whole time. You should definitely be getting better than 6mpg.
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
