Water in the oil
Old Aug 23, 2007 | 09:47 PM
newbie454's Avatar
Default Water in the oil
I have a 98 AC 454 that runs great but it gets water in the oil. Its from the cooling system not from being submerged. Any suggestions? Could this be the water pump? I know there is a seal on the shaft. Would that do it or is this likely catastrophic?
Old Aug 24, 2007 | 08:12 AM
Mobilized 1's Avatar
Has the engine been overheated? Usually water in the oil is a head gasket or a cracked head and once in a while a cracked block. The first two can be fixed the block ussually not but thats not for sure. If its radiator fluid it is probably one of these three but I do not know arctic cat engines as well so maybe someone else has a different outlook on this!
Old Aug 29, 2007 | 01:47 AM
swampyjunior's Avatar
I agree with mobilized 1. You have a crack some place. You can do a compression check to check the head gasket OR what I like to do if you do not have a compression gauge is to remove the radiator cap and start the machine. If you have a blown head gasket or a cracked head the compression will blow antifreeze out the top of the radiator.
Swampy
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
