plows
Old Sep 19, 2007 | 08:57 PM
gordie580's Avatar
Default plows
I am planning on getting a plow for either the 500 cat or the 700 griz
Anyone have good and bad experiences with plows let me know.
any recomendations on brand?
Old Sep 19, 2007 | 09:04 PM
wildwest1011's Avatar
Default plows
nope..nothing bad. works good w/ a winch, put it on whichever machine is heavier, which I assume would be the grizz, but not sure. Some guys have had problems w/ the cables snapping, but just be carefull not to raise the winch too high (if you have one)........ good luck!
Old Sep 20, 2007 | 04:19 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default plows
I have used a lot of different plows, they are all good except I didn't like the Swisher due to the set-up, as it lowers your ground clearance to like 6". My favorite is the factory Arctic Cat 60" plow. That is what I am going to get for now on.
Old Sep 20, 2007 | 10:24 PM
buckaroo50's Avatar
Default plows
You can check these links for some ideas, Cycle Country can be purchased with its own mini attached winch.
http://www.motoxoutlet.com/ind...n=VIEWPROD&ProdID=226
http://www.psep.biz/store/arctic_cat_atv_plow.htm
Old Sep 21, 2007 | 04:00 AM
CaptainQuint's Avatar
Default plows
I've always had good luck with the cycle country plows. As far as lifting systems don't overlook the manual lift option. I like the manual lift for my gravel drive because it offers more of "feel" of how the blade is contacting and digging into the surface. I found it really helps in keeping the blade running just at the right level and tension to clean the snow without ripping up the gravel. I just couldn't do that with the winch. The "feel" wasn't there.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
