2005 650 V2
Old Sep 27, 2007 | 10:26 PM
JT 384's Avatar
Default 2005 650 V2
I have a 650 V2 and I noticed today that there was a lot of blue smoke when you first start it and when you rev the crap out of it. I also noticed that it smelled rich and its hard to start, even if you been on a ride for awhile.
So my question is what can I check? At the end of the last season the choke cable was changed if thats any help.
JT
Old Sep 28, 2007 | 01:29 AM
CATSKINNER's Avatar
Default 2005 650 V2
My 04 650 did the same thing. Turned out that the rear Carb's float was stuck open because the needle and seat was not working properly. All the gas that drained past the rings went into the crank case and thinned out the oil. When I started it and seen all the blue smoke, I shut it down and checked the oil and noticed it was over full because of the gas. It was still under warranty so the dealer replaced the needle and seat and changed the oil.
Old Sep 28, 2007 | 11:11 PM
JT 384's Avatar
Default 2005 650 V2
Thanks I will check to see if thats the problem. But if its not, what else could I check?
Old Oct 2, 2007 | 12:49 AM
Chumley's Avatar
Default 2005 650 V2
I'd check the air filter next, a plugged one will leave you with hard starting and smoke.
Old Oct 14, 2007 | 09:17 PM
JT 384's Avatar
Default 2005 650 V2
Checked air filter looks good. I took it to a ATV shop in town and he said the engin was cooked. CRAP!!!!!!!!!!!!!!!!!!!!!!!!!!
I did a compression test and and it was 57 pounds. Is that low? The bike was never sunk, and it only has 1053 miles. It was always hard to start. What can I do.
Please help.
Old Oct 20, 2007 | 01:06 PM
kitty05's Avatar
Default 2005 650 V2
My 05 650 got hard to start and had a loss of compression. It turned out to be the valves needed to be adjusted.
Old Oct 20, 2007 | 02:44 PM
JT 384's Avatar
Default 2005 650 V2
Thanks for the info
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
