New to Forum and 01 400 4X4 Question
[img]i/expressions/face-icon-small-disgusted.gif[/img]
I recently bought a new 2008 Honda Rubicon, White, (traded in my waverunner, for the wife) and I have a 2001 Arctic Cat 400 4x4 Green, I think shes jealous.
It will not hold charge. I replaced the battery while out at Hatfield McCoy's Trailfest '07, and it will run till the fan runs the battery dead since it has the constant fan, or you cut the headlights on and it will drain it even quicker.
I put a volt meter on and checked it, battery was at 13 volts, and charging, but no real fluctuation when using the throttle.
If there isnt enough juice to start it with the electric start, I can pull start it and it will run until the battery goes dead.
I have a trickle charger on the battery and it is charging as it is supposed to.
Any Suggestions from you all?
Thanks for your help!
Steve from VA
Steve from VA
bpegram84
Jul 22, 2015 08:15 AM
