Thundercat CARB certification up
The Thundercat 950 finally is up on the CARB site.
CARB tested the 950 as 49.1 kw/65.84 hp.
The other big bore ATVs:
The Can-Am Outlander 800 46kw/61.69hp
The Kawasaki Brute Force 749 37.1 kw/49.75hp
The Polaris Sportsman 760 36kw/48.28hp
The Suzuki King Quad 722 37kw/49.62hp
The Yamaha Grizzly 686 34kw/45.59hp
The Honda Rincon 675 28.7kw/38.49
That is a disappointing number. How on earth can it beat a Renegade with higher gearing and a lower power to weight ratio? Maybe they did tune them down from what the original test models were. I would be suprised if it even beats and Outlander with those numbers.
<div class="FTQUOTE"><begin quote>Originally posted by: Crankdog
That is a disappointing number. How on earth can it beat a Renegade with higher gearing and a lower power to weight ratio? Maybe they did tune them down from what the original test models were. I would be suprised if it even beats and Outlander with those numbers.</end quote></div>
Hp is important but Torque is King!
How come my 07, 7200 lbs Crew cab diesel truck beats a 3500 lbs(est) 07 Dodge Charger with a hemi in it in a 1/8 mile drag race. They both have about the same hp, Diesel is 360 hp and the 07 Charger is 345hp/. The ansewr is Torque.
The diesl has 650ft/lbs of torque and the Charger has about 350ft/lbs of torque(est)
My truck did the 1/8mile in 9.87 sec and the Charger did it in 9.9secs.
GregM
Mar 6, 2018 06:53 AM
760, artic, atv, canam, carb, cat, certificate, certification, certifications, diesl, honda, hp, rincon, yamaha
