carb help on 04 AC 400 4x4!
Old Nov 14, 2007 | 07:18 PM
darkfoxx's Avatar
Default carb help on 04 AC 400 4x4!
My girl has a 04 AC 400 4x4 that is leaking gas from the overflow tube coming out from the carb bowl.
she said that she had the carb serviced, but i believe they just cleaned and replaced a few parts and not the float or it's components.
what do ya recommend to fixx this prob it leaks gas and will not stop i have to keep a jug under it al all times to catch the gas that it escaping.
Old Nov 14, 2007 | 08:52 PM
400crasher's Avatar
The float must be sticking and not rising to shut the gas flow off. I had my carb apart on the quad, had it turned sideways and the pin that holds the float in place slipped out. i finally found it on the garage floor and put it back together. Yours is either sticking or fell apart as it was being put back together. Since mine was still on the quad, I spent 45 minutes hunting down where all the parts fell on the motor and garage floor.
Old Nov 14, 2007 | 08:56 PM
darkfoxx's Avatar
so just get a new float assembly?
Old Nov 14, 2007 | 08:59 PM
400crasher's Avatar
Find out what is wrong first. Whoever worked on it may have screwed up. Nothing should have to be replaced yet. It may just be gummed up and need cleaning. I would bet its a free fix,,,,,
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
