Winch Selonoid Placement
Old Dec 14, 2007 | 07:57 PM
Crypto's Avatar
Default Winch Selonoid Placement
I'm going to install a winch tomorrow. I'm curious where you guys who have the same model have placed the selonoid?
thanks
Old Dec 14, 2007 | 10:00 PM
Off_Road_Ram_01's Avatar
Mine's under the seat - pretty much between were the front seat mounts come down at.
Old Dec 14, 2007 | 10:28 PM
Crypto's Avatar
great. Thanks for the pic
Old Dec 14, 2007 | 11:33 PM
rango726's Avatar
thats were most people put them. they dont really leave you much room to put them
Old Dec 14, 2007 | 11:40 PM
No not much room anywhere - I was debating putting in the storage trunk too, but found it just barely fit there. Was debating cutting the wires that came with the winch to reduce the amount I had to stash by the battery.
Old Dec 15, 2007 | 07:01 AM
Crypto's Avatar
no there isn't much room. THanks again guys
Old Dec 16, 2007 | 10:41 PM
rango726's Avatar
you should cut all your wires to length. if you have all theat extra slack the extra wire just cut it and go with the amount that you need. if you read your directions it will tell you if you need to route the wires further than what they supply than youll need to go up a wire size. this is because of the voltage carried through the wire if its too long than your voltage drops and you dont get the max out of your winch. if it even works at all granted your not going to see any difference if you cut off the extra wire or leave it especially were its only 6" of wire but. but you should cut it to size just to clean up the install
Old Dec 17, 2007 | 06:27 AM
Crypto's Avatar
what do you guys recommend for the switched power source? I was going to tie into the accesory on the handlebar, but I see it's not switched. I'll dig around and find one, but if you guys may be able to make it easy for me.
Old Dec 19, 2007 | 04:28 PM
QuadRidinCPA's Avatar
Sorry if I'm too late, but at the front of the handlebar, below the plastic piece, you will see a wire with a female bullet connector end on it. That's where you are supposed to plug it into. That's where it's at on my '06 anyway. Hope that helps.
Old Dec 19, 2007 | 07:30 PM
Crypto's Avatar
thanks. Do you mean inside the instrument panel or under the handlebars behind the body panel. I don't see a wire in the instument panel
