What drive belt should I use on my AC 650 V2?
Old Feb 9, 2008 | 11:01 PM
mirlkman's Avatar
Default What drive belt should I use on my AC 650 V2?
My drive belt light came on today and I assume it needs replacing as I couldn't get over 12 mph as I "limped" out of the woods. Any suggestions on a replacement belt or anything else that may cause the light to come on?
Old Feb 10, 2008 | 02:15 AM
CATSKINNER's Avatar
The belt light will come on every 100 hrs no matter what shape the belt is in. It is a service reminder to check the belt and clutches. I bet you have nothing wrong with your belt so you just need to Reset the limp mode and go. If you do have belt problems, go with the Brute Force 750 belt.
Old Feb 10, 2008 | 02:58 AM
weez440's Avatar
simplest fix. buy a dynatek cdi. it will NEVER go into limp mode again and gain you horsepower and make it run cooler. go to ebay and type it in i think they are around 200 now and well worth every penny. i bought one of the first ones for the 650 and it burnt out for no reason and i contacted the company in california. i sent it back and they sent me a new one and by the next weekend i had it. also it could be that the switch was tripped inside the clutch cover. if you have a dynatek though that won't matter if that is tripped either.
Ridgebackguy86
Sep 19, 2015 12:48 PM
patrick.oc123
Sep 16, 2015 03:45 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
