2004 arctic cat 90cc 4 stroke
Hello everyone I'm new here and I'm hoping to get some help and learn alot.
I was wondering if anyone knows the factory settings for this quad, I'm having troubl with it and want to set the carbs back to the factory settings.
thanks, mike
thanks, mike
whats your issue?? i dont know if there is a specific set up. my guess is that you played with the pilot metering screw.? start at about 3 turns out from fully seated but thats just a basis i dont know anything about what your prob is or were you live or what jetting you run etc etc. im not too savy with jetting im learning but ive learned a decent amount in the past few yrs.
I bought it from a dealer I live in plover,Wi I did not touch the pilot screw just the idle and the problems are when starting it does not want to start and it does not idle smooth, put a new spark plug in and fresh gas so I figure it must be the carb. The dealer said before they sold it they had to clean the carb but it just does not run right and I cant have them look at it because I did not buy the extended warranty.
thanks for the reply I hope some of what I said helps.
mike
mike
Customer Service #1
May 15, 2020 08:46 AM
Sw00p
Sep 24, 2015 02:50 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
