2000 arctic cat 300 4x4 wont stay started
Old May 1, 2008 | 10:21 AM
njjane's Avatar
Default 2000 arctic cat 300 4x4 wont stay started
I have a problem with my atv not staying started. It starts and as soon as I give it gas it dies. Even it I have it fully choked and dont give it gas it dies within a few seconds. Any ideas.
Old May 2, 2008 | 11:24 AM
buckaroo50's Avatar
It takes (air, fuel and spark) for an engine to run. These all have to be correct for it to run correctly.
Since it does start then you have some degree of all.
Since it stops running then the most logical is that it is not getting fuel or air - probably no fuel.
Check to make sure you have a good charge in your battery - the engine runs off the battery until it goes over 2000 rpm before the magneto takes over.
Make sure you have good fuel - not old stale fuel.
Clean your carb and air filter.
Make sure the on/off valve is on.
Make sure your air vent is not obstucted and causing a vacuum - thus stopping the fuel from flowing.
Hope this gets you headed in the right direction
Old Jun 24, 2008 | 11:04 AM
njjane's Avatar
Just to give update. Duh......I found out from my neighbor that was leaving the choke on all the time and after of 10 min of idle it would die. I could not get it off of choke because it seemed like it was getting little fuel. I checked the spark plug, It was all black. I changed the plug and still did not help. I did some reading on here and in the manual and decided to adjust the carb, since it was recently cleaned by a friend I thought well maybe he didnt set it correctly. sure enough I adjusted the carb a little and it purrs.. I also checked he plug after it ran for a while and it was fine. I am still having an issue though with 1st gear not lighting up. Any suggestions?
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
Dame0927
Oct 29, 2015 10:13 PM
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
