suspension help
Old May 10, 2008 | 07:18 PM
gvance's Avatar
Default suspension help
What are most people doing on there acs to help with diving and swaying back and forth.Do new springs work better with or without adding a swaybar.Want to add something to help my 2007 700 efi suspension.
Old May 10, 2008 | 08:37 PM
Uncle's Avatar
Do a search for discussion on shocks adjustments by Buckroo. Really good information on setting up setting. Solve my diving of the front end.
Old May 11, 2008 | 02:29 PM
buckaroo50's Avatar
As Uncle suggested to a search for 'how to make your AC handle better', there may be some info in there that may help without spending a dime.
It will explain some of your handling problems and point you in a direction to correct it with out guessing.
For starters try these setting and go from there:
Air pressures: 8 lbs in the front, 5 lbs in the rear.
Spring settings: Front on softest, Rear on next to softest or middle setting.
Good luck
The post is on the next page with around 8000 views.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
