Oil change question.
I went and got an oil change kit from the dealer I bought my 400 from and got it out to change the oil this evening and the filter is a different size than the on that came on it from the factory(first oil change). The rubber seal is the same size and it threads on fine, it is just a little smaller in diameter and a little longer. Also the P/N is different. I just didn't want to put it on and run it without finding out if they changed the filter design or it's just the wrong filter. Any thought's would be appritiated
I believe CAT just changed the oil filter in the last year or so. I was told it was due to them having the bypass in the filter changed but I am not sure about that.
I use Wix filters and they are the size of the older filters and cast about $5 each. Newer filter are $12 or so.
SJ
SJ
