650 ac 2004 choke cable
Old Oct 6, 2008 | 10:04 AM
usalee's Avatar
Default 650 ac 2004 choke cable
its it hard to do, any one
thank
usalee
Old Oct 10, 2008 | 10:12 AM
coopthehdrider's Avatar
Is it broken or just sticking? If it's just sticking then taking off at the lever on the handlebar and then disassembling the small black box half way down the cable and cleaning out oout all the heavy grease, lubing the 3 cables, working them as you lube and reassembling them should do the trick. Otherwise, replacing the cable requires removing the carbs, that is the easiest way.
BC
Old Oct 10, 2008 | 10:26 AM
usalee's Avatar
thanks
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
wrencher82
Sep 24, 2015 03:39 PM
Sw00p
Sep 24, 2015 02:50 PM
