Artic override in low range
Old Feb 3, 2009 | 05:48 PM
mudslinginfool's Avatar
Does it in the Mud!
Default Artic override in low range
is it like mine as i specified before? It works only in 4 wheel drive on the 4x4 models. The problem with vicrider2000 is something else b/c it does not have 4wd. Try your in 4 wheel drive, if it still cuts out then your right, you do have a problem and i do not know the answer.
Old Feb 4, 2009 | 08:38 AM
Moosicman's Avatar
Could it be that it is not quite in gear properly? I test drove an H1 700. It shifted easy and smoothly but twice when I put into high range it seemed to act like it was hitting a rev limiter at about 10mph. I took it out of high and put back in high and all was ok. Maybe the low gear shifter has to be realigned.
Old Feb 7, 2009 | 11:02 PM
91kx125's Avatar
my 07 cat is the same way!
SUZUKI ENGINES HAVE SHITY PROGRAMS!
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
