carb bowl drain
Old Feb 7, 2009 | 11:12 PM
fluffie's Avatar
Default carb bowl drain
I am having a problem with the carb drain tube leaking gas when the engine is running. The drain screw is closed tight. This is on a Arctic Cat 400 FIS. Any suggestions what could be wrong would be helpful.
Old Feb 8, 2009 | 08:41 AM
Royz4x4's Avatar
Probably trash in the needle valve, or the float is stuck/out of adjustment.
Old Feb 8, 2009 | 08:58 AM
king_crusher's Avatar
you need to remove the carb from the machine take it apart and clean it
when it leaks its usually from dirt in there typically the float is sticking open
Old Feb 8, 2009 | 04:19 PM
fluffie's Avatar
Thanks for the information. I took the screw out the bowl drain and cleaned the screw and flushed the bowl out. Everything is working fine.
Old Feb 8, 2009 | 06:56 PM
ChatterMan's Avatar
or the carb is loose in the rubber,and the carb is not settin straight
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Aitch
Jul 21, 2015 09:40 PM
