Wiring hand warmers
Old Nov 27, 2009 | 08:59 AM
fredd's Avatar
Default Wiring hand warmers
I am wiring hand warmers on an '04 Cat 500 auto. I am wondering where I will find a good place to tie into the power supply. I would like to be after the key so that I won't drain the battery if I forget to shut them off. I also am wondering about pulling the plastics. I assume that the black pins pull out from the center to release? I have a digital display if that matters. Thanks, all. Also, any brands to avoid/pursue on the hand warmers?
Old Nov 27, 2009 | 10:10 AM
Catman-doo's Avatar
there should be a acc. plug on the main wire harness under the handle bars . take the panel off under the bars, its a two wire plug . I have the AC hand warmers on my 07 500, 08 700, they work great..
Old Nov 27, 2009 | 09:46 PM
fredd's Avatar
how do I acces the panel?? from the side or top from around the speedo/odo display?? Thanks
Old Nov 28, 2009 | 09:14 AM
Catman-doo's Avatar
should be from the top, couple of plastic rivets hold down the black panel under the bars or they could be screws. I'm checking my rad fluid today I'll take some pic and try to post them
Old Nov 28, 2009 | 10:27 AM
fredd's Avatar
thanks catman
Old Nov 28, 2009 | 03:27 PM
Catman-doo's Avatar
took some pic .. should have a plug with nothing in it, orange wire,red and black.. thats the plug for the warmers or what ever..hope this helps ..plus I was board..lol. put ele grease on it and do all your plug ins
Attached Thumbnails Wiring hand warmers-hand-warmer-001.jpg   Wiring hand warmers-hand-warmer-002.jpg   Wiring hand warmers-hand-warmer-003.jpg   Wiring hand warmers-hand-warmer-004.jpg   Wiring hand warmers-hand-warmer-006.jpg
Old Nov 28, 2009 | 08:15 PM
fredd's Avatar
above and beyond the call of duty.....thanks again
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Austins
1) Engine problems..
Aug 9, 2015 02:28 AM
DeFox500
Jul 26, 2015 06:32 PM
ghost civic
Jul 19, 2015 10:13 AM
