Mudpro 4.0 gears...will they retrofit?
Old Feb 16, 2010 | 11:22 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Default Mudpro 4.0 gears...will they retrofit?
Does anyone know if the Mudpro's 4.0 gears will fit into standard 650, 700 or 1000 AC's?
Would love to have the correct gearing to run taller tires
Old Feb 17, 2010 | 05:25 AM
CATSKINNER's Avatar
Yes, you can change your gear ratio in other models. I had an 05 650 V2 with the higher gearing and in 06, Cat changed the V2 to 4.0 from the factory becuse of belt issues on the V2. Here is another option you may consider.
ArcticChat.com >> It's All About the Pride®
Old Feb 17, 2010 | 05:54 PM
No Ruts, No Glory
Thanks 'skinner....man, that is one tech-loaded forum for sure. That's definitely the place to go for the hard to answer questions
Cantbuytime
Aug 16, 2015 09:13 PM
jimmydm
May 3, 2011 01:40 AM
TexasRoadlawyer
Arctic Cat New 2011 ATVs And UTVs
Sep 24, 2010 09:41 AM
TexasRoadlawyer
Jan 18, 2010 12:46 AM
Steveo10
Feb 7, 2009 10:52 PM
