2003 Arctic Cat 300 Missfiring
Old Apr 8, 2010 | 03:11 PM
magnum350's Avatar
Question 2003 Arctic Cat 300 Missfiring
My 2003 Arctic Cat 300 will start fine and will run. But it does have a problem missfiring about every 5 seconds. It is getting worse over time and when idleing it will die. I have checked the pick-up coil, flywheel, wiring and connectors, ignition coil, spark plug, and valve clearence. All are good. I'm thinking strongly that I have a bad CDI box. I know it is not the carb because a timming light shows the erratic missfiring. Is there any opinions out there? I need help.
Old Apr 12, 2010 | 08:20 AM
Poorguy007's Avatar
My parents have 2 Arctic Cat 300's and they both do almost the exact same thing. Ive come to the conclusion that its the key switch thats messed up. If I turn the switch to where the headlights come on the thing runs like a top, but when I turn the lights back off it starts acting up again. Try turning your lights on and tell us how that does.
Old Apr 15, 2010 | 11:39 AM
magnum350's Avatar
Question
I tried that and it did the same thing with the lights on. Still believe it is the CDI. Thanks for the info--it sounded like a good possibility.
Old Apr 27, 2010 | 01:01 PM
sassee's Avatar
Check your voltage output. My AC 400 did the same thing. turned out to be the rectifier. It was putting out too much volts. If you are over15.5 (I think that is the magic number) you have a problem. I have an old post on here about that which has all of the specifics.
Customer Service #1
May 15, 2020 08:46 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
brad patnoe
Sep 23, 2015 06:44 PM
Hw00d
Sep 10, 2015 08:53 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
