Oil Change interval and other maintenance
Old Aug 30, 2010 | 10:37 AM
rlh6805's Avatar
Default Oil Change interval and other maintenance
I have both a 2007 650 H1 and 2008 Thundercat. The 650 has ~800 miles on it and the T-Cat has ~200. I bought them both used but they are in really good shape. How often should I be changing the oil. What about the air filter? What other maintenance items need to be periodically looked at? These are my first ATV's but I have had Snowmobiles for quite a while. One thing that they have in common is the drive belt and clutches. I was told by the dealer that unlike sleds where you have to change the belts every so often, you don't have to do this with these. Is this true?
Old Aug 30, 2010 | 11:54 AM
TLC's Avatar
TLC
I change the oil every 50 hrs like the manual states. I change the belts every 2000 miles no matter what, but I can get that far on my snowmobiles also. The belts on the ATV last longer then sleds because they have a low range option and do not have nearly the power or high RPMS as a sled motor has.
Old Aug 30, 2010 | 02:35 PM
taker80's Avatar
No belt worries till it slips, your front and rear diffs need fluid changed once in a while perhaps every 3 or 4 oil changes. There is a ton of info out there about your bikes and ways to mod them for power and such just have to look around a bit more!! Couple good forums for information is highlifter and arcticchat. I am a member on both those forums!!
caveeagle
Sep 19, 2015 01:20 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
