Artic Cat 366 brake light problem
Old Sep 1, 2010 | 04:56 PM
cspar's Avatar
Default Artic Cat 366 brake light problem
I have a 08 Artic Cat 366 and the brake light stays on. The brakes themselves are not engaged but the light remains lit. Any ideas?
Old Sep 2, 2010 | 10:38 AM
Duke_Of_URL's Avatar
Have you checked the switches? They could be sticking, particularly the foot pedal brake if you run the machine through muck and such.
Old Sep 2, 2010 | 11:00 AM
cspar's Avatar
What switches are you refering? Are they by the pedal/handbrake or down by the Master Cylinder? What should I look for?
Old Sep 2, 2010 | 09:27 PM
Mud Slinger's Avatar
Check the cables on the rear hand brake. On mine the brake light switch is on the lever and if the cable isn't adjusted to keep the lever tight, the loose lever will trip the light without engaging the brakes. If you adjust the cable to tighten up the lever it should take care of your problem.
MikeyBoyesq
Nov 27, 2020 02:44 PM
scaldwellk
Jun 19, 2015 05:08 PM
Jbird4681
Jun 9, 2015 01:59 AM
UPLou
Jun 7, 2015 09:42 AM
atving
Nov 17, 1999 09:24 PM
