Arctic Cat 300 Problems...
Old Sep 12, 2010 | 05:40 PM
Outdoorsman101's Avatar
Default Arctic Cat 300 Problems...
Hello, new to the website and planning on being an common user... anyways, I have a 2003 Arctic Cat 300 4x4 atv that will not hold it's battery charge. I've replaced the battery several times but before when i would check it it was charging fine. but just checked it with a new battery and its only at 12.6 Volts on a 12 volt battery, so i know that the bike isn't charging. i also contacted the local Arctic Cat dealer and they said it was common for a wire to wear on the voltage regulator. i haven't checked it out yet but was wondering if anyone has any ideas of what may be causing the problems. The bike is getting to the point where it broke down and luckily i had a friend riding with me to get back to my cabin. any help is greatly appreciated!
Old Sep 12, 2010 | 09:23 PM
mudslinginfool's Avatar
Does it in the Mud!
i too had a 300. it was a 1999 model but yes it did have the regulator fail which caused the battery to drain. basically a direct short. changed it out and it was good to go. The part at the time was $80.00. Not saying for sure this is it,but id check it out.
Old Sep 12, 2010 | 09:24 PM
Does it in the Mud!
i too had a 300. it was a 1999 model but yes it did have the regulator fail which caused the battery to drain. basically a direct short. changed it out and it was good to go. The part at the time was $80.00. Not saying for sure this is it,but id check it out. I didnt check mine but i saw it was burnt so i just changed it out.
Old Sep 13, 2010 | 01:21 PM
Thanks! I'm going to look into that and i thought that mat have been the trouble... i contacted my local arctic cat and for the model and year i have its 250+ bucks for it... so im gonna be sure thats it before i buy one... if anyone one got any other suggests to what it may be feel free to say!
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
