will not start
Old Oct 3, 2010 | 09:12 AM
lowery7's Avatar
Default will not start
I have a 02 arctic cat 300 4x4. The starter has been rebuilt but when you hit the start button all you can hear is the starter spinning, the motor will not turn over. You can use pull start but its a pain in the butt to crank it. I took side of the motor off and all the gears look good no broke teeth and put a new battery on it. Im lost and dont know what to do. If anyone can help it would be greatly appreciated. Thank you
Old Oct 3, 2010 | 10:50 AM
weez440's Avatar
you took the side of motor off??? i guess i don't understand. i would take the starter off as the starter drive is sticking inside the starter or your teeth on the starter drive or the ring gear are stripped. i am thinking the starter is sticking.
Old Oct 3, 2010 | 03:43 PM
lowery7's Avatar
Yes took side case off to see if any of the gears had wore or broke teeth.They all looked new.pulled starter out a little bit and it is sparking when i hit start button. I dont know alot about atvs but cant aford to take it to get it fixed.
Old Oct 3, 2010 | 09:37 PM
weez440's Avatar
sounds like your starter drive isn't sliding forward when it turns over. it is probably sticky. take it off and you will see what i'm talking about.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
